>I need some advice/help to find out which GPIB support is available for EPICS.
>Which hardware board should be used?
>- Is the Greenspring-IP solution ready (through HIDEOS?)
>- could the GPIB driver also run on native VxWorks?
> ( we would prefer our CDI interface)
The Greenspring-IP plus HiDEOS is running suprisingly well. The hardest
part is figuring out how to deal with the TI chip on the IP board. The
DOCs on it are written for a genious-level GPIB hacker (I am not one by
any measure.) I have run sustained load tests on multiple-devices hooked
to the IP board under HiDEOS. I have been recommending it over the NI
boards to users here.
The code for it is quite simple. However, I do not recommend starting
from scratch if you want one to run in your "CDI interface". I HIGHLY
recommend using the stuff I wrote as a road map to develop your own.
>Which support is available for LabViews?
>- is there a CA library?
>- is it fully integrated?
>- which platforms are supported?
As far as I know, nothing has been done for LabViews. A while back I
talked with some guys here at ANL that were interested, but nothing came
of it. Perhaps someone else has been made progress on it.
--John Winans
- question: GPIB-SUPPORT FOR EPICS Matthias Clausen DESY -MKV2/KRYK-
Re: question: GPIB-SUPPORT FOR EPICS Tim Mooney
Re: question: GPIB-SUPPORT FOR EPICS Dr. Pete Jemian
<1995>
2025
2026
strings Ian Smith
<1995>
2025
2026
