Comments on the status code proposal:
COMMENT 1:
Perhaps "errSubsysRegister()" should have two arguments:
1) a symbolic name for the subsystem (instead of a pointer
to the error code table) and
2) the sub system identification code (an unsigned integer)
We could use naming conventions and the sub system symbolic name
to find the error text table in the symbol table. I suspect that
this approach would be more likely to detect conflicts where two
sub systems are using the same sub system code. Also using a
symbolic name instead of a pointer will be less constraining on our
future implementation options.
COMMENT 2:
Perhaps we should start using an architecture independent type
to hold status instead of the C type "long". On some architectures
long is bigger than the natural data path between the processor
and memory. An architecture independent type will guarantee that
the status is held in a variable that is large enough but not
so large as to slow things down.
COMMENT 3:
Is a group code appropriate? I am worried that there may be more than 64
distinct sites and there may be more than 64 subsystems at a site. I am
less worried that there will be more than 4096 sub systems. Of course
a global sub system code will require that one site is responsible for
allocating sub system codes (and distributing a file that converts
a sub system code into a group name string).
Jeff
______________________________________________________________________
Jeffrey O. Hill Internet [email protected]
LANL MS H820 Voice 505 665 1831
Los Alamos, NM 87545 USA FAX 505 665 5107
RE: EPICS status codes proposal Marty Kraimer
Re: MBBO record support Peregrine McGehee
<1995>
2025
2026
Re: EPICS status codes proposal Jim B. Kowalkowski
more help with ar, please Ian Smith
<1995>
2025
2026
