Jeff,
On Wed, 25 Oct 95 11:06:39 MDT Jeff Hill <[email protected]> wrote:
>This problem is at least partially caused by the fact that my tar
>script (which I used to distribute the source to Chris Timossi)
>is specifically excluding everything in the O.xxx directories in
>order to minimize the size of the tar file. Perhaps we should establish
>the convention of storing the architecture specific source code in S.xxx?
>Perhaps S.build would be the correct place to store source files that
>are created during the build (but are common to all architectures)?
I guess we need to decide whether we want a general solution for created source
files, or a specific for this particular problem (maybe plus the blderrSymTbl
output as well).
For a general solution I suggest we should use O.something (O.src?) rather than
S.build as the O.* directories are already singled out for things like make clean,
which would allows us to remove the additional clean:: targets. I've just looked
though base and run diff on all the common .c files which exist in the object
directories and there are no differences between solaris and mv167 targets in any
of the sources generated. We currently have duplicate generated .c files in as,
dbtools and libCom.
If we only worry about this particular instance, you could just run bldEnvData
within your tar script -- it creates the envData.c file in the working directory.
This should be run by the make Win32 or make VMS targets when collecting all
the relevant source together, rather than just taking a copy of envData.c from
O.sun4 [or O.$(HOST_ARCH) to be safer].
I propose that for the 3.12.2 release you use the latter approach, but the general
solution should be considered for future releases.
- Andrew
O o ._ Andrew Johnson, Royal Greenwich Observatory
__\\_ Madingley Road, Cambridge, CB3 0EZ
__|ooooo|__ Tel +44 (0)1223 374823 Fax 374700
~~\_________/~~ WWW http://www.ast.cam.ac.uk/~anj/
Re: NT changes for 3.12.2 Jeff Hill
Re: EPICS status codes proposal winans
<1995>
2025
2026
"mosub" Andy Foster
<1995>
2025
2026
