1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS status codes proposal
To: [email protected]
Cc: [email protected]
Date: Wed, 25 Oct 95 14:52:13 HST
I promise that this will be short... I find myself agreeing with almost all
that John Winans says. Some brief notes:
1. I mentioned DRAMA in order to be even-handed. I agree with John's comments.
2. As a matter of interest, why is the time stamp not the 11th quark? Is it
   never required along with graphic or control information?
3. The severity quark is fine for VALID / INVALID. The status quark has the
   problem that it is 16 bits and not easily extensible, hence much of the
   discussion to date. A message string quark would need to be more than a
   canned translation of the status
4. There is, I think, a distinction between a status which comes back to a
   client in a transaction response and a status which is part of a record's
   state.
5. I would happily throw out the requirement that status codes be converted
   to message text. It has been interest in upwards compatibility which has
   kept that alive. All along we have agreed that it is text which flows on
   the wire.
6. Small subsystem-specific error codes still don't address the "package A
   calls routine in package B which calls routine in package C which fails"
   problem unless B converts all C codes to B codes before forwarding them
   to A (which is a bit of a pain for B; I've several times written systems
   which were low-level and returned things like NULL to indicate failure,
   only to have to invent error codes at the next level up and to wish I'd
   done the job properly in the first place).
William
Prev: Re: EPICS status codes proposal winans
Next: Re: EPICS status codes proposal watson
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EPICS status codes proposal watson
Next: Re: EPICS status codes proposal Jim B. Kowalkowski
