1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: CAN connection
To: [email protected]
Date: Fri, 27 Oct 1995 13:16:20 +0000 (GMT)
On Fri, 27 Oct 1995 12:43:46 +0100 (MET) Gabor Csuka <[email protected]> wrote:
>The CAN bus now successfully connected to Epics (R3.12.1),
>useing CDI V4.0 interface.
For anyone who doesn't want to use the CDI, I wrote an EPICS CANbus driver which is
already in use on UKIRT (and will be used by Gemini).  This drives the TIP810 IP
module and has been tested using the Greenspring VIPC310 and VIPC610 carrier boards
but also has software to drive the mv162 (not tested).  Device support is provided
for ai, ao, bi, bo, mbbi, mbbo, mbbiDirect and mbboDirect records with full I/O
interrupt and asynchronous record processing.  You can even use EPICS to build a
simulator for another CANbus device to respond to RTRs on the bus.
Documentation is in preparation, and should be available shortly.
- Andrew
  O o ._    Andrew Johnson, Royal Greenwich Observatory
     __\\_	Madingley Road, Cambridge, CB3 0EZ
  __|ooooo|__	Tel +44 (0)1223 374823  Fax 374700
~~\_________/~~	WWW http://www.ast.cam.ac.uk/~anj/
Re: CAN connection Gabor Csuka
Prev: Re: Subroutine Records Marty Kraimer
Next: SUBSCRIBE tech-talk Gerhard Grygiel
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: CAN connection Gabor Csuka
Next: Re: CAN connection Gabor Csuka
