> > I found out that in general that the caget in ezcaIDL is
> > 3 times slower than CaIDL.
> > In case 1 a caget is repeated 100 times on an AI record, in case 2 a
> > caget is repeated 100 times on a waveform record with float type with 4000
> > elements ...
> > CaIDL ezcaIDL
> > Case 1 1 sec 4 sec
> > Case 2 3 sec 9 sec
> This is simply incorrect. These results were the result of using the ezca
> default timeout of .05 seconds. The correct comparison is with a very short
> timeout in ezca. In this case the following results are obtained on a
> Sparc LX.
> CaIDL ezcaIDL
> Case 1 0.72 sec 0.83 sec
> Case 2 3.05 sec 3.16 sec
> Thus, ezcaIDL is at worst 10% slower than CaIDL.
The actual time out I used in yesturday study for CaIDL, and ezcaIDL both
are 0.001 sec. And the time I reported is the "REALTIME" used.
Since Mark reported different time, therefore I did exactly the same
calculation as Mark did again today.
The time used on my Sparc 20 are listed below, I use the same 1.e-6 timeout
in both cases.
CaIDL ezcaIDL
Case 1 0.41999996 sec 2.161000 sec
Case 2 2.6480000 sec 4.217000 sec
The actual run for CaIDL and ezcaIDL are atached below, I just can not
believe why the version of ezcaIDL on our system is much slower then what
Marks's Sparc LX.
RUN FROM CAIDL
kao 186: idl
IDL. Version 4.0.1 (sunos sparc).
Copyright 1989-1995, Research Systems, Inc.
All rights reserved. Unauthorized reproduction prohibited.
Installation number: 2421-1.
Licensed for use by: Advanced Photon Source
Compiling CaWave ...
Compiling CaWidgets ...
CaWave Version 3.1(Lca2.2) (EPICS Version 3.12.1.3)
IDL> capendevent,time=1.e-6
IDL> t1 = systime(1)
IDL> for i=1, 100 do s = caget('chademoai1')
t2 = systime(1)
print, 'Elapsed time for caget on AI: ', t2-t1
t1 = systime(1)
for i=1, 100 do s = caget('chademowfmax7')
t2 = systime(1)
print, 'Elapsed time for caget on 4000 element waveform: ', t2-t1
IDL> t2 = systime(1)
IDL> print, 'Elapsed time for caget on AI: ', t2-t1
Elapsed time for caget on AI: 0.41999996 <=======
IDL> for i=1, 100 do s = caget('chademowfmax7')
IDL> print, 'Elapsed time for caget on 4000 element waveform: ', t2-t1
Elapsed time for caget on 4000 element waveform: 2.6480000 <=======
IDL>
RUN FROM EZCAIDL
kao 205: idl
archsun4
/usr/local/epics/extensions/bin/sun4:/usr/local/epics/extensions/bin/sun4:/usr8/rsi/idl_4/lib/hook:/usr8/rsi/idl_4/lib/obsolete:/usr8/rsi/idl_4/lib:/usr8/rsi/idl_4/examples/hdf_ncdf:/usr8/rsi/idl_4/examples/general:/usr8/rsi/idl_4/examples/wexmast
Run ezcaIDL ...
Run ezcaIDLWidgets ...
IDL> casettimeout, 1.e-6
t1 = systime(1)
for i=1, 100 do s = caget('chademoai1', value)
t2 = systime(1)
t1 = systime(1)
for i=1, 100 do s = caget('chademowfmax7', value)
t2 = systime(1)
IDL> for i=1, 100 do s = caget('chademoai1', value)
Elapsed time for caget on AI: 2.1610000 <=========
IDL> for i=1, 100 do s = caget('chademowfmax7', value)
Elapsed time for caget on 4000 element waveform: 4.2170000 <=========
IDL>
Re: ezcaIDL vs CaIDL Mark Rivers
Re: New Subroutine Record Marty Kraimer
<1995>
2025
2026
Converting edd displays to edd2 Paul Martin
<1995>
2025
2026
