> From [email protected] Wed Nov 8 13:31:50 1995
> Return-Path: <[email protected]>
> Date: Wed, 8 Nov 95 10:29:45 HST
> To: [email protected]
> Subject: Re: AR in server mode and cmdClient
> Content-Length: 881
> X-Lines: 24
> Dear all,
> Peregrine wrote:
> > cmdClient is in base at $EPICS/base/src/util/cmdClient.c and the
> > executable should be in $EPICS/base/bin/<arch>.
> Deb Wrote:
> > Perry indicated where to find it. My version of 3.12 indicates that
> > base/src/util/cmdClient.c was put in the cvs Attic at some point.
> > If you can't find it in your release of EPICS, it's probably retrievable
> > there somewhere. I'm not sure if we should get it set up in extensions/ar
> > or what.
> I assume that most of the stuff from base/src/util was moved to
> extensions/ar/syd? Apparently cmdClient.c was omitted?
> Anyway, as a stopgap, I have moved cmdClient.c (I had it in the Attic
> from Beta1) there too and butchered the Makefile to build it (it
> introduces a cross-dependence between ar/syd and ar/ar which needs
> fixing since cmdClient needs ezsSockSubr which is in ar/ar...).
> Thanks for your help,
> William
Hi William,
When I moved arr (the tck/tk archiver retriever) into EPICS for solaris,
I ran into a similar problem needing routines that used to be in
libCom for 3.11 but were restricted to ar in 3.12.
I created a library called arAccessLib that had all of those components
of ar which used to be in libCom and are not in syd. Janet has put
it in the newer 3.12.xx Makefiles for extensions/src/ar/ar. The library gets
installed in extensions/lib. When your AR_cmd gets integrated back with
epics, you should be able to obtain ezsSockSubr from that library.
Rozelle
Re: AR in server mode and cmdClient Jeff Hill
iocInit hangs connecting to the log server Jeff Hill
<1995>
2025
2026
<1995>
2025
2026
