I am considering using the Digiplan SD series of modular stepper
motor drivers in the Gemini Multiple Object Spectrograph. As with
all Gemini Telescope instruments, the controller for GMOS uses
EPICS and the Oregon Microsystems series of stepper controllers
(in this case the VME8-8).
The SD12 driver can be used with size 23
or 34 bipolar motors, 0.5 to 2 amps per phase, 200 or 400 steps
per revolution, and 10,000 steps/s max. rate. Up to 6 modules
can be mounted in a 3U, 19 inch rack. The 20 stepper motors
used in GMOS will require 4 racks, or about 21 inches of rack
space.
Has anyone come across a more compact, off-the-shelf solution?
Has anyone used the SD12 in particular, or chopping motor controllers
in general, in instruments? Any problems with CCD or IR detector
interference?
Brian Leckie
Dominion Astrophysical Observatory
Re: A possible alignment fix side-effect. Jeff Hill
passing arrays via input links Kevin Tsubota
<1995>
2025
2026
<1995>
2025
2026
