1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: A C++ API for the pcas
To: [email protected]
Date: Thu, 7 Dec 95 12:27:09 MST
Hello all,
I am considering using a C++ API for the new portable ca server
library. As I see it there are two primary concerns that must be
addressed:
1) Sites that use the new ca server lib must have a C++ compiler.
Most vendors are now releasing one compiler that eats both ANSI
C and C++. Otherwise under UNIX you can always use g++ as long
as any header file/library difficulties are sorted out. For vxWorks
it is reasonable to get g++ and configure it as a cross compiler.
Does tornado include a properly configured gnu C++ cross compiler?
2) There are many existing C codes which would like to export
EPICS process variables.
In this case a small C++ glue code could be created and this could be
used call the existing ANSI C code whoose function prototypes are
shrouded by "extern "C" {". There is also the possibility of creating
a C API which is a wrapper for the C++ API.
If the possibility of a C++ API for the new CA server causes you grief
please reply to this message so that we can make an informed decision.
Thanks
Jeff
______________________________________________________________________
Jeffrey O. Hill			Internet	[email protected]
LANL MS H820			Voice		505 665 1831
Los Alamos, NM 87545 USA 	FAX		505 665 5107
Prev: Re: passing arrays via input links Kevin Tsubota
Next: Re: A C++ API for the pcas William Lupton
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Wind River - vxWorks/Tornado Bob Dalesio
