1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: A C++ API for the pcas
To: [email protected]
Date: Thu, 7 Dec 95 12:54:44 MST
> From [email protected] Thu Dec  7 12:28:05 1995
> Return-Path: <[email protected]>
> Date: Thu, 7 Dec 95 12:27:09 MST
Jeff Hiil writes:
> Most vendors are now releasing one compiler that eats both ANSI
> C and C++. Otherwise under UNIX you can always use g++ as long
> as any header file/library difficulties are sorted out. For vxWorks
> it is reasonable to get g++ and configure it as a cross compiler.
> Does tornado include a properly configured gnu C++ cross compiler?
Wind River says that GNU gcc 2.6 (C & C++) from Cygnus is bundled
with VxWorks 5.3 (Tornado).
Andy
Prev: Re: A C++ API for the pcas William Lupton
Next: Re: A C++ API for the pcas 415
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
