Subject: |
Bugs eventTask error message storm - BURT Unsigned values > 9 |
[email protected] (Marty Kraimer) |
Date: |
Fri, 30 Jun 1995 15:48:22 -0500 |
Two bugs new bugs have come to our attention.
1) eventTask ring buffer overflow
If post_event(event_number) causes a ring buffer overflow then it
always calls errMessage. Thus if the eventTask fails for some reason,
an error message storm occurs. If many events are being posted, messages
are printed at such a rapid rate that the vxWorks shell becomes unusable.
2) BURT for DBF_USHORT and DBF_ULONG fields.
If burt is used to save USHORT or ULONG fields then the value restored
will be a value between 0 and 9.
Here is the long-winded explaination of what happened.
BURT requests floats with DBR_FLOAT and doubles with DBR_DOUBLE.
and saves them in exponential format, i.e. x.xxxxxe+xx.
It restores them, however with DBR_STRING.
Because old database access doesnt know about unsigned quantities
the interface between old and new database access tells the user that
the native field type for USHORT is float and for ULONG is double.
Thus BURT asks for USHORTS with DBR_FLOAT and ULONGs with DBR_DOUBLE (this w
as
done to prevent large positive numbers from appearing as negative numbers)
It then saves them in exp notation. When the restore is done as a DBR_STRING
dbPutField uses integer type conversions which means that everything startin
g
with "." is ignored.
Here is an example. Lets say that the MRES field of the steppermotor record
has the value 2000. BURT asks for it with DBR_FLOAT and saves it as "2.00000
e+3".
When it is restored with DBR_STRING the format used for conversion is "%hu".
This results in a restored value of 2.
I will be on vacation next week. When I get back I will start placing known 3.12
bugs on the APS/EPICS WWW documentation.
Marty Kraimer
Re: ansi? Jeff Hill
MV147 Bob Dalesio
<1995>
2025
2026
Re: ansi? Jeff Hill
MV147 Bob Dalesio
<1995>
2025
2026
