BURT
I am trying Solaris versions of burtrb and burtwb (many thanks
to Andrew Johnson, by the way).
I am using exactly the same files that I used under SunOS.
I have now the following diagnostics :
**** READ BURT LOGFILE
--- Start processing files
file >/home/sigx0/sig/ttf/burt/injector/inj1.req<
preprocessing ... ERROR: BurtPreprocessFile() cc abended exit_status 1 signal
-1ERROR: process_command_line_args() could not preprocess non-SDDS file
when I try a backup
and :
STEERER_H0INJ1_ONbo ... ca_array_put() nelem 1 ... OK
STEERER_H1INJ1_ONbo ... ca_array_put() nelem 1 ... OK
STEERER_H2INJ1_ONbo ... ca_array_put() nelem 1 ... OK
STEERER_H3INJ1_ONbo ... ca_array_put() nelem 1 ... OK
flushing with ca_flush_io() ... OK
--- End writes
did not find any read only notify values ... NO OUTPUT FILE CREATED
when I try a restore.
Another point : burtrb and burtwb needs to link libXt.so.5.0 and
libX11.so.5.0 at startup. Why ? Moreover, Solaris 2.5 is delivered with
libXt.so.4.0 and libX11.so.4.0 .
KM
My Sundials are not seen by the Solaris version of km, although some other
programs run fine with them.
They are connected to tty/a and the configuration is done with bdconfig.
Thanks in advance
JF Gournay
CEA Sacaly
km under Solaris Fred Vong
Re: Burt and km under Solaris John R. Winans
<1996>
2025
2026
<1996>
2025
2026
