1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Policy on C++ compilers
To: [email protected]
Date: Fri, 16 Feb 96 16:26:53 HST
Regarding Andrews point:
> It does if you realise that the binaries he is using were copied from APS's
> /usr/local/epics/extensions/bin/solaris directory, where they were compiled
> against X11R5 rather than openwin.  I can't build BURT here because it won't
> compile using g++.
What is the official Epics policy on C++? Some of the bigger labs seem
to be getting heavily into C++ and talking to Jeff the other day the
new portable channel access server will not work without C++. However,
I get the feeling that there is also a lot of us out here who haven't
been able to use any of these new tools since we don't have the `right'
C++ compiler.
I understand the Epics policy with C is that we use the compiler
supplied by the OS vendor - but that is made much easier by there being
an ANSI standard. With C++ I get the feeling there is still a bit of
variation between compilers since the standard hasn't been cast in
stone yet. This variation may be an argument for g++, but I understand
that also doesn't work.
So, can someone in the know please:
1. Let me know whether I have to go and buy a SunSoft C++ compiler for
   Solaris.
2. List all the Epics software that uses, or is dependent on, C++, and
   what range of hardware, operating system and compiler it has been
   tested on.
Thanks
Nick Rees
Joint Astronomy Centre                    Ph:       +1 (808) 961-3756
660 N. Aohoku Place                       Fax:      +1 (808) 961-6516
Hilo, HI.  96720                          Internet: [email protected]
Prev: Re: Field type Jeff Hill
Next: Re: macro substitution William Lupton
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Policy on C++ compilers Jeff Hill
