1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS Access Security
To: [email protected], [email protected]
Date: Wed, 21 Feb 96 11:29:26 MST
> I have some questions/comments on EPICS "Access Security":
> (1) I wanted to see the effect of stopping a user from accessing
> data values with "dm", by using a suitably set-up access security file.
> It did work. However, I was somewhat surprised by the message returned in
> the "dm" text box which was "No data available". It was only when I looked
> at messages in my command tool that I realised that access was being denied.
> I don't see at present, how the user, just from looking at the "dm" screen could
> tell that access was being denied? Couldn't "dm" be made clever enough to distinguish
> the cases of "No data available" and "Insufficient Access"? At 14,000 ft
> misleading messages will lead to even greater confusion when a system is
> being debugged!
CA does provide this information to the client library API. However,
it may take awhile before all clients have been updated to use it.
> (2) In another scenario, I was making a database in IOC1 send a command to
> a database in IOC2. By sending a command, I mean writing to a field of a record
> in IOC2 which had ASL = 0 and PP = YES in the ascii file.
> I found that when the command
> was blocked by the access security mechanism, the following appeared on the IOC1
> shell (sender of the command):
> task: 0Xe7d640 dbCaOutput
> dbCa_unknownECA ERROR: queue_ca_put() unrecognizable status returned 376
> Bus Error
> Program Counter: 0x00f0bc72
> Status Register: 0x3000
> Access Address : 0xf8609ffc
> Special Status : 0x0485
> Task: 0xe4f338 "process_asynch_events_task"
> When I saw "Bus Error" I was rather shocked. Should blocking out access really
> cause such an error to occur in the sending IOC or is this indicative of a
> more serious error?
> I sort of expected a nice message to appear saying "access denied".
This looks like a bug in the db links code (it appears to be unable
to handle an unexpected ca error code - in this case ECA_NOWTACCESS).
Jeff
Prev: EPICS Access Security Andy Foster
Next: Re: rCVS William Lupton
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EPICS Access Security Marty Kraimer
Next: Re: EPICS Access Security Deb Kerstiens
