Mark writes:
>Wouldn't an obvious solution/rejoinder be that when these screens are =
>created, you basically build some for the power (read/write) users; =
>different ones for the infidels, uh, rest of the world, and come up with =
>some compromise for the group that has limited access and so falls =
>somewhere between?=20
In fact this is something we also thought about.
But then - to avoid all the double work to support all screens twice( read and
read/write screens) - we thought of an -in screen- password that will
enable/disable write access to any record on this screen. This would help to
solve the problem of:
- special read and read/write screens
- security for screens called up by any X-terminal
- flexibility to call up read/write screens on X-terminals you had not thought
of during configuration of your security databse
The password could be even an environment variable and/or a part of the screen
configuration.
This mechanism is ment to me a safety feature to avoid undesired changes. The
passwords does not necessarily have to be really secure. The operator should
have to pass a 'barryer' before changing a value.
To implement this we would need a 'password-button' which you press to pop up a
box to enter the password. If write-access is not allowed all widgets should
look like those where CA-security does not allow write access - a flag for all
write-records on one screen.
We have good experience with this method. The operators know several different
password to perform different actions like:
tuning/editing/display-only/sequencing
This is implemented to avoid undesired changes in the system during night
shifts.
In addition it would help if any write action to the IOC's could be logged on a
file. This would help to keep track and analyse problems. This would need an
output channel from the CA-server on the IOC to a (i.e.) NFS-mounted disk.
The output would look like:
date time user@machine changed record from value to value
Matthias
Matthias Clausen Deutsches Elektronen Synchrotron
DESY
Gruppe: MKS2/KRYK
Notkestrasse 85 VXHERA::CLAUS
D-22607 Hamburg Bahrenfeld [email protected]
Tel: -49 40 8998-3256 [email protected]
Fax: -49 40 8998-4388 PSI%(0262)45050958002::CLAUS
Re: Omissions in 3.12.2 Marty Kraimer
Driver for Joerger VTR1012 Rainer Goergen
<1996>
2025
2026
<1996>
2025
2026
