1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Logging of Write Actions
From: Stephanie Allison (415)926-4534 <[email protected]>
To: [email protected]
Cc: [email protected]
Date: Fri, 23 Feb 1996 8:52:08 -0800 (PST)
Matthias wrote:
>In addition it would help if any write action to the IOC's could be logged on a
>file. This would help to keep track and analyse problems. This would need an
>output channel from the CA-server on the IOC to a (i.e.) NFS-mounted disk.
>The output would look like:
>date time user@machine changed record from value to value
This must of been discussed in the past.  Sorry if this is a rehash.
I agree that we need a mechanism for logging changes by the user and
that the user, host, channel name, and old and new values need to be
in the message.  I think the logging should be by the client instead of the
IOC CA servers.  If somebody is knobbing a setpoint (or using a slider or
doing a correlation plot), we wouldn't want a message for each change.
Instead, the knob client should log when the user first assigns a channel
to a knob and perhaps some periodic time after that.  If somebody is
restoring a backup (which may include hundreds of channels), the client
should just log the name of the backup that got restored.  When the user
does an individual text update, message, or choice button,  the change
should be logged by the display manager.  But this should be configurable -
this should be an option that the display creator can set.  It would be
nice if at the time a controller is created, EDD provided a on/off field
for logging changes.  If set, DM would send the change to some server or
write to some file - configurable using environment variables.
++ Stephanie    [email protected]
Re: Logging of Write Actions watson
Prev: Re: logging writes Jeff Hill
Next: Re: Logging of Write Actions watson
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
