hello all,
I am thinking that we should add display arguments declaration to
"modify display attributes" in edd. This would be a single
parameter with the following syntax:
"<arg0> {= <default>} , <arg1> {= <default>} , ..."
example:
"BPMNO = 1, SECTOR = blue, BLDG"
In this case when starting the display if they dont specify a value
for the macro "BPMNO" then the value assigned will be "1". If they
dont specify "SECTOR" then the value "blue" will be assigned.
If they dont specify "BLDG" then they will be prompted for this
argument via a dialog box.
For backwards compatibility (and convenience) if the display
arguments declaration isnt provided (is empty) then dm would continue
to operator as it does today (without argument checks).
I see three main advantages to this approach:
o better error messages if the arguments are over/under specified
o optional defaults for arguments (allows adding new arguments to a display
without breaking preexisting callers of the display)
o the possibility of prompting for missing arguments via a dialog box
Jeff
______________________________________________________________________
Jeffrey O. Hill Internet [email protected]
LANL MS H820 Voice 505 665 1831
Los Alamos, NM 87545 USA FAX 505 665 5107
Re: Logging of Write Actions watson
Re: dm display arguments declaration William Lupton
<1996>
2025
2026
<1996>
2025
2026
