Deb,
[snipped my comments]
> The display list was recently modified to include formats on text_entry
> objects. My plan was to allow hex numbers if the format was set to do so,
> and have it be an error otherwise. Alternatively, for DBR types that are
> not double or float, I could just allow them. (I could even allow them
> for floats and doubles, but I'm not sure that it makes as much sense.)
> Comments? I'm assuming that if the hex format was chosen, CA updates to the
> text_entry object would reflect that choice. Last question: if the hex
> format is selected, do I reject input other input? (I vote no, as long as
> it fits the %i format of scanf)
> Ditto for octal format....
By "format" do you mean scanf style formats? My guess is that that would be
preferable. Along with my don't do the user any favors philosophy, I would
not check the DBR types when interpretting a number. The user should get what
(s)he asks for if at all possible, even if (s)he gets something other than
what (s)he intended. So if (s)he asks for %i format for a double, an integer,
octal or hexadecimal representation of a double should be entered. (S)He'll
change it when (s)he grows tired of it. Thus reject it only if scanf does.
By the way, I would consequently suggest that "text update" objects show hex
numbers with a leading "0x" or "0X" rather than a trailing "x" to be
consistent. Ultimately, when drag-and-drop is implemented, a number like 13x
won't be accepted by scanf when dropped on a "text entry" object, never mind
arguments invoking potential operator confusion. Maybe "text update" objects
should also be modified to accept a format specifier (perhaps as a menu choice
so the current scheme doesn't break anything)?
> > I find that in some cases undesired behavior is produced when continuously
> > updating the .VAL field with a changing valuator. I realize that this behavior
> > can be changed with the menu on the live valuator, but I would rather like to
> > be able to set the defaults in this menu with edd when the valuator is created
> > or modified.
> Also in the display list, so you can configure it in edd. Soon (hopefully) it
> will be implemented in dm. I, too, hate to have to configure things every
> time I bring up a display.
> > Ric
> Deb
Great, Deb. Thanks very much!
Ric
Re: dm Deb Kerstiens
logging writes - 2nd round Matthias Clausen DESY -MKV2/KRYK-
<1996>
2025
2026
<1996>
2025
2026
