I am in the process of writing device support for the Allen Bradley 1746-HSTP1
stepper motor controller module. I was running into a problem under 3.12.1 in
which the database specified initialization algorithm (Move to the
Negative/Positive Limit) was being aborted by the record support smcb_callback
routine with a SM_MOTION command. In looking at 3.12.2 I see that this
problem has been fixed. However, the initialization algorithms have changed
as well and now no longer reliably provide enough motion for an HSTP1 to get
a motor to one of its limits. The HSTP1 can keep track of up to +/-8,388,607
steps whereas 3.12.2 requests only +/- 1,048,575 steps. Under 3.12.1 the
algorithms used to request +/- 268,435,455 steps.
How can we fix this? I would prefer the implementation of a new command:
SM_FIND_HOME with an argument giving the direction to move in. That way, any
stepper motor support function can determine for itself what "Find Home" means,
whether it is a motion of a controller dependent number of steps or a special
function such as the "Find Home +/-" function of the HSTP1.
Failing that, I would suggest leaving the SM_MOVE commands, but with argument
+/-0x7fffffff. That way it is easily detectable by the stepper motor support
routines what is wanted. If the number is too big for some stepper motor
controllers to handle, the stepper motor support routine can replace it with
whatever it can handle. Meanwhile, I can still detect it and replace it with
the proper "Find Home +/-" command.
I really don't like this last method since it is overloading the meaning of
the arbitrary number with a specialized function that does not necessarily
cause a standard motion manoever. It is also the wrong number for 64 bit
systems.
I don't mind making the modifications necessary to recSteppermotor.c, drvOms.c
and drvCompusm.c, if the usual maintainers of these files are swamped.
However, since I don't have the relevant hardware, I can't test the OMS or
Compumotor cases.
Cheers,
Ric
Re: DEC Alpha OSF-1 generated database Marty Kraimer
Re: sequencer Andy Kozubal
<1996>
2025
2026
Re: Anyone using Tornado yet? Jeff Hill
Events lost, discard count was XXX Gabor Csuka
<1996>
2025
2026
