1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: ?delay record
To: [email protected], [email protected]
Date: Wed, 6 Mar 1996 10:18:47 -0600
> Does someone support a delay record?
> We need a record which is triggered by an EPICS event
> waits for about 0.3 sec
> and starts a chain of other (passive) records
> The time resolution of the record should be about 50mS
> Matthias
The sequence record can do this, for each output link has an associated
delay (DLY1, DLY2. DLY3, ...). Set the SCAN field to EVENT.
The WAIT record can also do this. The field .ODLY specifies a delay before the
output link is executed. The advantage of the WAIT record is that one can
make the execution of the output link "conditional", based on a calculation
of the inputs. It also has the "reassignable" links.
The advantage of the sequence record is that you have 10 links. If .DLY1 is
set to .3 and all other .DLYx are set to 0, it executes all 10 links after
the delay.
In both cases, the resolution is the 16.6667 ms tick clock.
        Ned
Prev: tcl_et Diana Kennedy
Next: Re: Bug in ca_pend_event() ? Jeff Hill
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: tcl_et Marty Kraimer
Next: ?delay record Matthias Clausen DESY -MKV2/KRYK-
