1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: User-defined menus for dm
To: [email protected], [email protected]
Date: Thu, 7 Mar 96 09:35:16 MST
Len writes:
> Is there any way to add user-defined menus to a dm window?
> What we would like to do is display menus in an EPICS interface.  Later on
> we shall be using Tcl/Tk for user interfaces but for the time being we need
> to develop a simple engineering interface for cryostat control.  Very often
> there is a set of choices, which we have been selecting by typing names or
> values into a text entry field.  We would much prefer to present the engineer
> with a fixed set of options in many cases, via a menu of some kind.  The names
> of the options and any associated values are supplied from a file read down
> from the host, so it would be nice to set up the menu dynamically, i.e. at
> runtime.
> In edd/dm it is easy enough to connect to a record field which already has
> multiple choices built in, by using a choice or menu button.  The question is,
> is there any way to adapt this for user defined lists?
There is currently no way to add user-defined menus in dm. (It's a nice idea,
though.)  I'm not sure if this would help solve your problem, but you can use
an "execute script" in dm to call up a TCL/TK script (or any script or
executable).
Deb
Deb Kerstiens		[email protected]
Phone			(505)667-3396
LANL AOT-8,MSH820	PO Box 1663, Los Alamos, NM. 87545
Prev: EPICS 3.13 ALPHA Release (3.12.2.2) Marty Kraimer
Next: Compressing postscript files. Nick Rees
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: User-defined menus for dm Len Lawrence
Next: LANL EPICS WWW site now mirrored in the UK Philip Taylor
