1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Problem changing to use ASCII database
To: Marty Kraimer <[email protected]>
Cc: [email protected]
Date: Wed, 27 Mar 96 09:55:14 -0500
RE: PP vs NPP as the default
>What to do??
So, it seems we have gotten into the undesireable position of having
two tools with different defaults.  It is more important I think to
have a global default than to fix the problem for any one class of
users, so the question becomes what SHOULD the default be?  I think
that NPP should be the default, as the static db access lib has it.
It should be easy enough for sr2db to have a switch to override this
default behavior (i.e. you must take explicit action to set PP).
Chip
Re: Problem changing to use ASCII database Marty Kraimer
Prev: Re: Problem changing to use ASCII database Marty Kraimer
Next: Re: Problem changing to use ASCII database Rozelle Wright
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
