I am totally confused over how default values are used
from 'edb.def' (if at all).
Example:
I tried, as a test, adding the ASG field to a binary-in
record. I added ASG to the 'sym' file with no value against it
i.e. ASG:
Running 'sch2edif' gave me an 'edf' with no reference to the ASG
field at all.
Then, running 'e2sr' gives the warning:
Warning: No property, port, or default value for "ASG", using " "
which is fine except that in the 'edb.def' file, I had explicitly
added:
(ASG (char(default "ENGINEERING")))
It doesn't surprise me that 'e2sr' was unable to find a value for ASG
from the 'edf' file since this contains no reference. But, then how can
you use 'edb.def' to set a default? I would have thought 'sch2edif' would
pick up the ASG field even though no value had been set against it and this
would enable 'e2sr' to use 'edb.def' for default values.
Have I got the wrong end of the stick?
It seems to me that in the current system, default values are set
through the 'sym' files?
I was doing this in an attempt to get rid of the many warnings that are
generated from 'e2sr'.
Andy
Andy Foster
Royal Greenwich Observatory Tel: 44 (0)1223 374899 (direct)
Madingley Road Fax: 44 (0)1223 374700
Cambridge E-mail: [email protected]
CB3 0HA Home Page: http://www.ast.cam.ac.uk/~ajf
UK
Re: CA API: Future directions? Peregrine McGehee
S: CapFast Symbols for mbb*Direct Ralph Lange
<1996>
2025
2026
Re: X Window Software for x86 Chris Timossi
<1996>
2025
2026
