1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Proposed stepper motor code modifications
To: [email protected]
Cc: [email protected]
Date: Wed, 10 Apr 1996 15:28:14 -0700 (PDT)
  Below are my proposed stepper motor related changes to be submitted for
inclusion in the next release of EPICS.  I didn't list the corresponding
necessary changes to steppermotor.h and choiceRec.ascii.  The effect of
these changes are to provide a motor controller independent way of finding
the limit switches and to add support for finding a home switch.  Motor
controller support routines are thus free to interpret what these concepts
mean (or to ignore them) whereas previously record support dictated the
meaning of finding a limit switch.  Are these agreeable to everyone?  I
realize that this breaks non(Compumotor and OMS) support that may be out
there, but the changes the owners would have to make are small.
  I have also completed device support for the Allen Bradley 1746-HSTP1
stepper motor controller and would like to submit it for inclusion in the
next release of EPICS, as well.
		Ric Claus
recSteppermotor.c / init_sm:
	if (psm->mode == POSITION){
		if (psm->ialg != 0){
>			switch (psm->ialg){
>			case (POSITIVE_LIMIT):
>				status = (*pdset->sm_command)(psm,SM_FIND_LIMIT,1,0);
>				break;
>			case (NEGATIVE_LIMIT):
>				status = (*pdset->sm_command)(psm,SM_FIND_LIMIT,-1,0);
>				break;
>			case (POSITIVE_HOME):
>				status = (*pdset->sm_command)(psm,SM_FIND_HOME,1,0);
>				break;
>			case (NEGATIVE_HOME):
>				status = (*pdset->sm_command)(psm,SM_FIND_HOME,-1,0);
>				break;
			psm->sthm = 1;
		/* force a read of the position and status */
		}else{
			status = (*pdset->sm_command)(psm,SM_READ,0,0);
drvCompuSm.c / compu_driver:
	case (SM_VELOCITY):
		compu_motor_data_array[card].velocity = arg1;
		compu_motor_data_array[card].accel = arg2;
		/* set the velocity */
		compu_msg[0] = SM_DEF_VEL_ACC;
		compu_msg[1] = 0;		/* time is in seconds */
		compu_msg[2] = 0;
		pint = (int *)&compu_msg[3];	/* velocity */
		*pint = arg1;
		pint++;				/* acceleration */
		*pint = arg2;
		compu_send_msg(pcompu_motors[card],compu_msg,11);
		break;
>	case (SM_FIND_HOME):            /* Move to a home switch */
>		break;                  /* Not supported by this device */
>	case (SM_FIND_LIMIT):           /* Move to a limit switch */
>		arg1 = arg1 >= 0 ? 0x000fffff : -0x000fffff;
>		/* break purposely left out to continue with SM_MOVE */
	case (SM_MOVE):
		if (compu_motor_array[card].mode == VELOCITY_MODE)
			return(0);
		/* move the motor */
		i = 0;
		compu_msg[i++] = SM_MOV_REL_POS;
		pint = (int *)&compu_msg[i];
		*pint = arg1;
		i += 4;
		compu_send_msg(pcompu_motors[card],compu_msg,i);
		/* set the motor to active */
		compu_motor_array[card].active = TRUE;
		/* wakeup the compu task */
		semGive(compu_wakeup);
		break;
drvOms.c / oms_driver:
	case (SM_VELOCITY):
		motor_data_array[card][channel].velocity = arg1;
		strcpy(oms_move_msg,"A?\nVL");
		oms_move_msg[MOTOR_POS] = oms_motor_specifier[channel];
		count = cvtLongToString(arg1,&oms_move_msg[5]);
		strcat(oms_move_msg,"\n");
		oms_send_msg(oms_motor_present[card],oms_move_msg);
		/* set the acceleration */
		strcpy(oms_move_msg,"A?\nAC");
		count = cvtLongToString(arg2,&oms_move_msg[5]);
		break;
	case (SM_MOVE):
		strcpy(oms_move_msg,"A?\nAF\nMR");
		oms_move_msg[1] = oms_motor_specifier[channel];
		count = cvtLongToString(arg1,&oms_move_msg[8]);
		strcat(oms_move_msg,"\nGO\n");
		oms_motor_array[card][channel].active = TRUE;
		/* wakeup the oms task */
		semGive(oms_wakeup);
		break;
Prev: error in mbbiDirect-record-processing Thomas Birke
Next: Possible Problem with aao Record Eric Bjorklund, NPSM
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
