1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: calling ca from fortran
Date: Wed, 24 Apr 1996 16:02:27 -0600
This is a multi-part message in MIME format.
--------------7566F4CF42877E5C33590565
Content-Type: text/plain; charset=us-ascii
Content-Transfer-Encoding: 7bit
Mark M. Ito wrote:
> I am trying to do the unthinkable: call channel access from a FORTRAN
> program (thought I'd capitalize that just to iritate this
> audience). Having attended college in the 70's, I am a bit behind
> these object-oriented times. Is there a set of sockets out there to
> allow this?
If you are willing to use the DEC FORTRAN extensions then it should
be possible to call the CA client lib "C" API directly from FORTRAN.
I understand that the DEC extensions are somewhat of a defacto
standard and that they have been available from SUN since the
early 90s. This will require a clear understanding of the
argument passing mechanisms employed by C and FORTRAN. This
approach has been used successfully by members of AOT-6 here at LANL
for channel access clients running on a VAX.
C functions that require strings will cause some grief (C expects
nill terminated strings most FORTRAN implementations store strings
in a data descriptor). One posssible solution: write a small C
routine that takes a FORTRAN string and returns a nill terminated
C string back to the FORTRAN caller. This nill terminated string
could then be passed to the CA client API.
Jeff
Content-Disposition: inline; filename="signature"
______________________________________________________________________
Jeffrey O. Hill                 Internet        [email protected]
LANL MS H820                    Voice           505 665 1831
Los Alamos, NM 87545 USA        FAX             505 665 5107
--------------7566F4CF42877E5C33590565--
Prev: Re: Programming software for Allen-Bradley SLC-500 Bill Lavender
Next: Mixing C and Fortran brian
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: calling ca from fortran Tim Mooney
