1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: IRM and EPICS
From: Matthias Clausen DESY -MKV2/KRYK- <[email protected]>
To: [email protected]
Cc: [email protected]
Date: Fri, 17 May 1996 9:35:18 +0200 (MET-DST)
Bill Brown writes:
>Is anyone using an IRM (Internet Rack Monitor) to run EPICS (as opposed
>to HiDEOS)?
We are running EPICS on the IRM and fully support nearly all I/O modules.
Only the swift Ai- board is currently not supported.
What do you mean by (as opposedto HiDEOS)
I do not see a HiDEOS OR IRM. The IRM I/O should be used as any other direct I/O
hardware using EPICS driver and device support. HiDEOS to my understanding does
deal with asynch I/O (as well as our CDI - common driver interface - does).
Driver support is not part of the current EPICS distribution but can of course be
copied from us. The description can be obtained from:
http://herao1.desy.de/cc/www/doc/irm.html
Regards
Matthias
   Matthias Clausen		Deutsches Elektronen Synchrotron
					      DESY
			   Gruppe: MKS2/KRYK
			   Notkestrasse 85	    VXHERA::CLAUS
			 D-22607 Hamburg Bahrenfeld [email protected]
			   Tel: -49 40 8998-3256    [email protected]
			   Fax: -49 40 8998-4388    PSI%(0262)45050958002::CLAUS
Prev: Thanks ! ... and next problem... (RE: [Q] Dynamic link object.) MURANAKA Masaki
Next: GPIB concerns in R3.13.0alpha3 John R. Winans
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: IRM and EPICS Bill Brown
Next: Thanks ! ... and next problem... (RE: [Q] Dynamic link object.) MURANAKA Masaki
