1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Build shared base libraries
To: [email protected]
Date: Sun, 19 May 96 23:09:43 EDT
This mail is made of the recycled electrons
Mailer: Elm [revision: 70.85]
> monaka wrote:
> > I know these extensions works so fine, but those link dynamically
> > their parts only.
> > My wish is to make base libraries (libDb.a, libca.a, ...).
> > This is difficult?
> I have made base shared libraries: libca.sl, licCom.sl at CEBAF.
> To have current R3.12.2 config files to support building both
> shared and achived base libraries, you need modify 3 files in
> config/ and Makefile.Unix in base/src/ca/ (or base/src/libCom/).
> Let me include what I did. I will work with Janet Anderson at
> APS to commit this support into the standard epics distribution.
> Hope that helps.
> Johnny Tang
> CEBAF
> Note: the line marked with * is new line
>       and marked with + is modified line
> 1. add two lines in CONFIG_SITE
>    INSTALL_LOCATION_LIB        = $(INSTALL_LOCATION)/lib
> *  INSTALL_LOCATION_LIB_SL     = $(INSTALL_LOCATION)/lib_sl
>    INSTALL_LIB                 = $(INSTALL_LOCATION_LIB)/$(T_A)
> *  INSTALL_LIB_SL              = $(INSTALL_LOCATION_LIB_SL)/$(T_A)
>    Define a location for shared libs and seperate shared libraries
>    from achived ones:
>    base/lib and base/lib_sl
> 2. add one line in CONFIG.Unix.hp700 ( or CONFIG.Unix.<host-arch> )
>    COMPILE.c = $(CC) $(CFLAGS) $(CPPFLAGS) -c
> *  COMPILE_SL.c = $(CC) $(CFLAGS) $(CPPFLAGS) +z -c
> 3. add/modify lines and rules in RULES.Unix
>    INSTALL_LIBS=$(LIBNAME:%=$(INSTALL_LIB)/%)
> *  INSTALL_LIBS_SL=$(LIBNAME_SL:%=$(INSTALL_LIB)/%)
> +  build: pre_build $(LIBNAME) $(LIBNAME_SL) $(TARGETS) $(PROD)
> +  install: build $(INSTALL_INC) $(INSTALL_LIBS) $(INSTALL_LIBS_SL) $(TARGETS) $(INSTALL_PROD) $(INSTALL_MAN1) $(INSTALL_DOCS) $(INSTALL_SCRIPTS)
>    clean::
>         @echo "Cleaning"
> +       $(RM) *.o *.a $(TARGETS) $(PROD) $(LIBNAME) $(LIBNAME_SL) $(INC)
> *  %_sl.c: ../%.c
> *       $(RM) $@
> *       ln -s $< $@
> *  %_sl.c: %.c
> *       $(RM) $@
> *       ln -s $< $@
> *  %_sl.o: %_sl.c
> *       $(COMPILE_SL.c) $<
>    %.o: %.c
>         $(COMPILE.c) $<
>    %.o: ../%.c
>         $(COMPILE.c) $<
>    $(LIBNAME): $(LIBOBJS)
>         @if [ ! -z "$(LIBNAME)" ] ; \
>         then \
>                 echo Building library $@; \
>                 $(AR) $(ARFLAGS) $@ $(LIBOBJS); \
>                 $(RANLIB) $@; \
>         fi
> *  $(LIBNAME_SL): $(LIBOBJS_SL)
> *       @if [ ! -z "$(LIBNAME_SL)" ] ; \
> *       then \
> *               echo Building Shared library $@; \
> *               echo ld -b -o $@ $(LIBOBJS_SL); \
> *               ld -b -o $@ $(LIBOBJS_SL); \
> *       fi
> #  This rule has to be before the next one
> *  $(INSTALL_LIB)/%.sl: %.sl
> *       echo "Installing shared library $< to $(INSTALL_LIB_SL)"
> *       test -d $(INSTALL_LOCATION_LIB_SL) || mkdir $(INSTALL_LOCATION_LIB_SL)
> *       test -d $(INSTALL_LIB_SL) || mkdir $(INSTALL_LIB_SL)
> *       $(INSTALL) -m 644 $< $(INSTALL_LIB_SL)
> $(INSTALL_LIB)/%: %
>         @echo "Installing library $< to $@"
>         @test -d $(INSTALL_LOCATION_LIB) || mkdir $(INSTALL_LOCATION_LIB)
>         @test -d $(INSTALL_LIB) || mkdir $(INSTALL_LIB)
>         @$(INSTALL) -m 644 $< $(INSTALL_LIB)
>         @$(RANLIB) $(RANLIBFLAGS) $@
> 4. add two lines in base/src/XX/Makefile.Unix
>    where XX is ca, libCom, etc
>    LIBOBJS = ...
> *  LIBOBJS_SL = $(LIBOBJS:%.o=%_sl.o)
>    LIBNAME = libca.a
> *  LIBNAME_SL = libca.sl
> Johnny Tang     Voice: (804)249-7239  E-Mail: [email protected]
> Continuous Electron Beam Accelerator Facility
> 12000 Jefferson Avenue, MS 85A
> Newport News, Virginia 23606
Prev: Bug and Fix Report Release 3.13.0Alpha3 Marty Kraimer
Next: GPIB-1014 with Nitro60 Andy Kozubal
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
