the vxWorks Users Group Exploder wrote:
> > We are using an MVE177 with 68060 CPU and seeing greatly degraded FP
> > performance when dealing with numbers whose magnitude are less than
> > FLT_MIN. This can cause a fabs() call to go from 1 microsec to 53
> > microsec! Similar degradation occurs for all FP Math operations.
> > Has anyone else seen this and can suggest a workaround. This is of
> > great concern to us in a high speed (1KHz) application which is math
> > intensive.
> Yes, you are getting underflow exception errors. You'll have to figure
> out how to turn that off. This is a problem on 167 boards as well.
> We had first noticed this when comparing performance of applications
> running single-precision vs. double-precision calculations. We were
> surprised to see that the single-precision version ran slower.
> The reason was that it (a simulated controls system) was doing such a
> good job that the errors in the system were below FLT_MIN, thereby
> generating underflow exceptions. It took the double-precision
> application much longer to hit its underflow limit, so it ran faster
> before that point.
> We "fixed" the problem by injection noise on the order of FLT_MIN into
> the system, since we couldn't disable exception-handling for
> underflow.
______________________________________________________________________
Jeffrey O. Hill Internet [email protected]
LANL MS H820 Voice 505 665 1831
Los Alamos, NM 87545 USA FAX 505 665 5107
Re: CA questions Jeff Hill
EPICS PostScript Documents Roland Mueller
<1996>
2025
2026
Burt compile. MURANAKA Masaki
<1996>
2025
2026
