re...
>... We at least found two places
> that causes the incompatibility between SNL/SEQUENCER 1.8.3
> and 1.9:
> 1. var_ptr in 1.8.3 vs. pVar in 1.9
> Solution: Global replacement / use #ifdef
> 2. Some SNL built-in functions are no longer working in
> escaped C code with 1.9, but was working with 1.8.3
> Solution: modify the SNL code (many places !)
> Is there any one in the collaboration running into the same
> problems ? Can you share your solutions to the above
> problems we ran into with us ? Or have you found any other
> places that causes the difficulty to port SNL code from
> 1.8.3 to 1.9 version of SNL/SEQUENCER ?
We ran into problem (2) also, and now we have two versions of our
SNL programs. We could generate the differences algorithmically, e.g.,
< pmacP = macValueGet("P");
> pmacP = seq_macValueGet(ssId,"P");
but we don't have enough affected code to make the effort worthwhile.
Since escaped C is no longer shielded from changes in the syntax of
underlying function calls, as it was when translation was done by the C
preprocessor, we could be doing this again.
Tim Mooney
Beamline Controls & Data Acquisition
Advanced Photon Source
SNL/SEQUENCER 1.9 not backwards compatible Johnny Tang
Re: New database. Marty Kraimer
<1996>
2025
2026
versioning convention Johnny Tang
<1996>
2025
2026
