Dear all,
The file:
ftp://ftp.keck.hawaii.edu/pub/wlupton/symb-1-0.tar.gz
is now available and contains new INST_IO vxWorks global variable device
support, implemented as proposed in tech-talk a couple of months ago. It
has been tested but not in a production environment. Comments are welcome.
The README file is appended.
William
README file for dev/symb directory
This directory contains all files necessary to build and test a version
of EPICS vxWorks global variable device support which uses the INST_IO
string as the variable name specification rather than deriving the name
from the record name.
In addition to specifying a variable name, a leading "*" operator indicates
that the variable is a pointer and a trailing "[nnnn]" indicates that an
element of an array should be accessed.
Refer to the header comments of devSymbFind.c for full details.
The following files are in the release:
README This file
Makefile UAE Makefile
Makefile.Vx UAE vxWorks Makefile
devAiSymb.c Modified versions of standard EPICS
devAoSymb.c vxWorks global variable device support
devLiSymb.c
devLoSymb.c
devSiSymb.c
devSoSymb.c
devSymbFind.c New module containing parsing code
(includes conditionally compiled test routine)
devSymbTest.c Defines globals and a routine for test
devSup.ascii New INST_IO entries for the above six records
symb.sr Test database (works with devSymbTest.c)
symbStartup.vws Test vxWorks startup script
08-Jun-96, William Lupton ([email protected]), CVS tag: symb-1-0
first release
Re: mv162 only Pete Jemian
Re: mv162 only Paul Banta
<1996>
2025
2026
Re: mv162 only Johnny Tang
fwd: a note from hurikon about performance John R. Winans
<1996>
2025
2026
