1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: mv162 only
To: [email protected]
Date: Mon, 10 Jun 1996 09:53:01 -0500
>Q: Why does this happen?
>In file CONFIG_SITE, I set
>CROSS_COMPILER_TARGET_ARCHS=mv162
>since the only crate processor I have is a mv162.
>Then I rebuilt EPICS R3.12.2 base.
>Here's the output from when the crate boots.
>-----------------------------% clip here %-----------------------------
>ld < targetmv162/iocCore
>undefined symbol: ___eqdf2
>undefined symbol: ___gtdf2
This is because you have 'soft-float' defined somewhere and are not loading
the floating point emulation libraries that come with vxWorks.  I don't
know *how* you are supposed to load them... I don't use that stuff, but
I suspect that if you build vxWorks for soft-float, they are built in.
I also suspect that you have a board with floating point on it... are loading
the vxWorks w/o soft-float (as you should for that board) and are just building
EPICS wrong (for a soft-float environment.)
>Q: Do I need to compile for BOTH the mv162 AND the mv167?
>That is,
>CONFIG_SITE: CROSS_COMPILER_TARGET_ARCHS=mv162 mv167
Not that I am aware of.
>Q: Is this a bug?
Nope.  It is a feature ;-)
--John Winans
Prev: Re: mv162 only Paul Banta
Next: fwd: a note from hurikon about performance John R. Winans
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: mv162 only Rozelle Wright
