1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Vanishing OUTLINKS
To: [email protected]
Date: Fri, 21 Jun 1996 09:02:52 -1000
Aloha,
Under EPICS R3.12 (specifically Version R3.12.0Beta13) I find the
following behavior:
Given two records A and B in the same lockset with A.OUT = "B .PP .NMS".
If record B is separately processed by hand and later record A is
processed B is (surprise!) no longer processed as a result of A's
OUTLINK even though B is still in the same lockset as A.
As an example:
	cp:if:mcs:dir.OUT = "DB_LINK pp=1 ms=0 mcs:cmd:move.DIR"
# enable trace messages
-> dbpf "cp:if:mcs:dir.TPRO", "1"
-> dbpf "mcs:cmd:move.TPRO", "1"
# get locksets
-> dbgf "cp:if:mcs:dir.LSET"
DBR_SHORT:          1         0x1
-> dbgf "mcs:cmd:move.LSET"
DBR_SHORT:          1         0x1
# force A to process
-> dbpf "cp:if:mcs:dir.PROC", "1"
process:   cp:if:mcs:dir
process:   mcs:cmd:move
# force B to process
-> dbpf "mcs:cmd:move.PROC", "1"
# check B's lockset
DBR_SHORT:          1         0x1
# force A to process again
Even though the two records are still in the same lockset and A's
OUTLINK still points to B, the link no longer operates!
This construct is being used to switch subsystems in and out of
Standalone modes. A possible workaround is to add two new records C
and D such that:
	A.OUT = "C .PP .NMS"
	C.FLNK = "D"
	D.DOL = "C"
	D.OMSL = "supervisory" in standalone mode, "closed_loop" otherwise.
	D.OUT = "B .PP .NMS"
I can't use an FLNK from A since A and B may be on separate IOCs.
Peregrine
Peregrine M. McGehee			http://www.cfht.hawaii.edu/~mcgehee
Telescope Control Systems Group 	Canada-France-Hawaii Telescope
(808) 885-3178				P.O. Box 1597, Kamuela, Hawaii 96743
Re: Vanishing OUTLINKS Marty Kraimer
Prev: Re: EPICS_IOC_LOG_FILE_COMMAND William Lupton
Next: Re: Vanishing OUTLINKS Marty Kraimer
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: CVS Bakul Banerjee
