On the subject of CAMAC serial drivers, I note the following:
1) the original CEBAF/TJNAF version supports multiple IOC's sharing a
single serial highway, and no LAM support. Single threaded operation
is guaranteed by disabling pre-emption during hardware access, and
by using the hardware mutex for multi-IOC operation. On hard errors
on the serial highway a short delay (~100 usec) is incurred.
Statistics are kept on the total number of operations, noX, and noQ.
2) the LANL version supports only a single IOC, but multiple serial
highways, and with LAM support. Single threaded operation is
guaranteed by the use of semaphores. On hard errors on the serial
highway, a full 1 second delay is seen by the scan task processing
the record if the expected interrupt is not delivered! We saw this
problem this week -- the IOC appears to run 10,000 times slower than
normal :) Different statistics are kept, with some errors being
tracked on a slot by slot basis, and other statistics kept by the
original version no longer tracked. A few useful convenience routines
are included.
CEBAF/TJNAF is working on merging these two versions. The choice between
semaphores and pre-emption disable will be made on the basis of performance,
although I suppose it could be a compile time switch for those who dislike
disabling pre-emption.
Chip
- [Summary] CAMAC Serial Driver Noboru Yamamoto
Re: [Summary] CAMAC Serial Driver Eric Bjorklund, NPSM
<1996>
2025
2026
<1996>
2025
2026
