1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: SNL 1.9 troubles
To: [email protected]
Date: Fri, 9 Aug 96 18:14:58 CDT
William Lupton wrote:
>   I suspect that you may not be using the "recursive" option. Without
> it, all state-program variables are simply statics and are therefore
> shared between instantiations. With it, each instance has a private copy
> of all variables. To set it, either use the "+r" flag to the "snc"
> command or else add the line
> option +r;
The example code already has the line allowing the recursive option.
option +r;
Andy reported back that I should upgrade to SNL 1.9.1.
Having done that, the problem is slightly different but
still does not work correctly.  (That is, setting pj:debug1 = 1
allows output for task "test1" and not for task "test2" _but_
setting pj:debug2=1, with pj:debug1=0, does not allow any output
from either task.)
The problem still is not fixed by using SNL 1.9.1.
I think the flaw is with SNL
(or an incompatibility with SNL 1.9.1 and EPICS R3.12.2).
Thanks for the help,
   Pete
Prev: Re: SNL 1.9 troubles William Lupton
Next: Re: SNL 1.9 troubles William Lupton
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
