I'm writing driver, device and record support for a set of custom VXI
modules. These modules have several functions, but share a number of
things like a subset of the VXI A16 registers, interrupt handling, etc.
Because of the desire to keep things self consistent and efficient, I
created one record type per module type. This makes for fairly messy
device support, as there is a lot of checking going on to figure out
which record field changed that caused the record to process. Does
anyone have a cleaner way to deal with this? Perhaps something to the
effect of using RSET->special to figure out which field caused
processing
and using that information (somehow) to tell RSET->process which
DSET->process
function to call? Perhaps call DSET->process in RSET->special directly?
Second, the records properly handle Is and Os from/to the modules when
they are marked scan passive. However, the modules can also raise
interrupts when they detect faults. I would like to get that
information
into record fields for display on an operator screen. Setting up for
the I/O Event scan mode appears to lock out processing due to
modification
of record fields from operator screens. Calling db_post_events from the
ISR seems to have no effect. There is really no need (currently) to
call
the process routine, but the record must be updated. What is the proper
way to handle both of these modes of operation?
Currently I'm running 3.12.2 and will upgrade to 3.12 as soon as I get
a chance.
Ric
Ric Claus ([email protected], (415) 926-2697)
- Re: rec/devSup advise needed Gabor Csuka
- Re: rec/devSup advise needed Ric Claus
Re: ANL vxWorks 5.2 Bakul Banerjee
tclCa package (was et_wish) Claude Saunders
<1996>
2025
2026
R3.13.0beta1 available Marty Kraimer
<1996>
2025
2026
