1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: epics driver & device support for IP modules
From: Matthias Clausen DESY -MKV2/KRYK- <[email protected]>
To: [email protected]
Cc: [email protected]
Date: Thu, 22 Aug 1996 16:45:20 +0200 (MET-DST)
>Hideos uses one "standard model" for supporting IP cards providing you
>are using C++ and an MVME162
Some comments on Hideos:
If you use IP modules which directly handle analog and digutal signals like those used for
the IRM you probably are better off using the direct access to the memory of the IP than
using an indirect way through an intermediate system. This implies that a general solution
has to take into account that there are different flavours of boards - some you directly
access and some ( like serial communication boards) that are better handeled by a
dedicated CPU to take care of all te asynchronous interrupts. In the latter field you are
using packages like HIDEOS or CDI.
An additional thought should be spent on the usage of drivers you provide for one ore the
other package. You probably want to be able to run the same driver - and save development
efford - regardless whether you run it on a dedicated CPU ( through HIDEOS or CDI) or on
the same CPU. (which to the best of my knowledge is only possible with CDI)
This design feature of CDI did help us a lot when we ported our CAN driver with the CAN IP
to the PC hardware with the IP on a ISA /IP carrier board.
We should get some more input on this from other users of IP modules.
Matthias
Re: epics driver & device support for IP modules Jim B. Kowalkowski
Prev: Re: epics driver & device support for IRM Bill Brown
Next: Re: epics driver & device support for IP modules Jim B. Kowalkowski
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: epics driver & device support for IP modules Andrew Johnson
