1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: epics driver & device support for IP modules
To: [email protected], [email protected]
Date: Thu, 22 Aug 1996 11:52:55 -0500
Matthias writes...
> If you use IP modules which directly handle analog and digutal signals like those used for
> the IRM you probably are better off using the direct access to the memory of the IP than
> using an indirect way through an intermediate system. This implies that a general solution
> has to take into account that there are different flavours of boards - some you directly
> access and some ( like serial communication boards) that are better handeled by a
> dedicated CPU to take care of all te asynchronous interrupts. In the latter field you are
> using packages like HIDEOS or CDI.
> An additional thought should be spent on the usage of drivers you provide for one ore the
> other package. You probably want to be able to run the same driver - and save development
> efford - regardless whether you run it on a dedicated CPU ( through HIDEOS or CDI) or on
> the same CPU. (which to the best of my knowledge is only possible with CDI)
> This design feature of CDI did help us a lot when we ported our CAN driver with the CAN IP
> to the PC hardware with the IP on a ISA /IP carrier board.
> We should get some more input on this from other users of IP modules.
Our plan is to host IP's that require lots of processing, interrupts,
etc. on a 162 running HIDEOS, and host less processor-hungry IP's on a
162 that runs both EPICS and HIDEOS.  We will still be going through
HIDEOS to talk to the local IP's, which is perhaps less efficient than
dedicated support for these local modules could be, but we won't have
to support two IP-interface mechanisms, and we'll be able to move an IP
from one board to the other by changing one number in the ioc-startup
file.
We haven't run IP's on the EPICS processor yet.
Tim Mooney
Prev: R3.13 App Devl Guide Janet B. Anderson
Next: Re: rec/devSup advise needed Marty Kraimer
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: epics driver & device support for IP modules Jim B. Kowalkowski
Next: R3.13 App Devl Guide Janet B. Anderson
