1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Seeing forward links from SNL?
To: [email protected], [email protected]
Date: Tue, 27 Aug 96 08:29:42 HST
Steve Wampler wrote:
> We have an application where some SNL code needs to be able to detect
> that the forward link out of a record has been activated (so the SNL
> can change state).  Is this possible?  How?  Thanks!
You could place a CALC record which increments its output by 1 each time
it executes (or an AO record with a negative .MDEL) at the end of the
forward link chain. Then the sequence could monitor that. Does that
help?
William
Prev: Seeing forward links from SNL? swampler
Next: Test Plans and Procedures Anna M. Estes
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
