1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: A multiway switch record for the new switchable links.
To: [email protected], [email protected], [email protected]
Date: Tue, 8 Oct 1996 17:05:09 -0500
> [email protected] (Nick Rees) sez:
> > I have been using R3.13.0 alpha 5 for a while now, and even had
> > occasion to use the switchable links. What we appear to need now is a
> > switch record, and probably a multipole, multiway switch record.
> > I have thought a bit about how this could work. Take the example of a
> > single pole multiway switch which can make a single input link switch
> > between a number of fields. Ideally it would appear on the database
> > diagram as connected on its input side to the multiple fields it is
> > switching between, and connected on the other (output) side to the
> > single input link. There would be a multiple choice selection mechanism
> > like the mbb records to select which field the input link refers to.
> Hmmmm - the hardware term that come to mind is "mux" (multiplexer).
> To be complete, a "de-mux" would also seem to be appropriate.
> One could probably bash someting together as a proof of principal using
> a subroutine record.
> Oh, what tangled paths we weave.....
> -bill
The SELECT record that is included in standard EPICS can be used as a mux.
	Ned
Prev: Re: A multiway switch record for the new switchable links. Bill Brown
Next: EPICS 3.13 Ric Claus
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: A multiway switch record for the new switchable links. Nick Rees
