I got base built, and managed to build extensions against it. It all seems
to works, but I've noticed something unusual.
I'm using a slight modification of the examples database that was included
in the release. (the only modification is to increase the range of values
generated by the calc record) I've got a little dm (v2.2) screen with 3
monitors of different types looking at the aiExample record. The calc
record is scanning 1/second and is forward linked to the ai record.
On the dm screen I would normally expect to see the value change once/second.
What I'm seeing is that frequently an update won't happen for 3 or 4 seconds.
When it does happen it jumps to the (apparently) correct number.
This is on a sun4 environment, SPARCstation 5, ioc is mv167/8mb, 25MHz.
AFAIK the network is lightly loaded.
Has anyone seen anything like this. I could swear that before (on older
releases) I've always seen a nice smooth update rate when watching a changing
pv. 'Tis a puzzlement.
-bill
RE: ai/ao RAWL RAWH Gabor Csuka
Re: R3.13.0beta2 Deb Kerstiens
<1996>
2025
2026
<1996>
2025
2026
