Geng XIAOSONG wrote:
> Salut, EPICS folks!
> We have some proposal about IOC logger..
General Comments:
It is true that the original log server is quite primitive and that
it is easy to imagine a number of improvements that could be made to
it. Perhaps the first items on the list should be improvements related
to configuration of a large system incorporating many IOCs.
My main concern is that upgrades are coordinated
so that the improvements at one site do not conflict with
improvements made at other sites. This will minimize the size of
the source code and the time required to train new users.
For example, KECK has recently made changes which allow the log server
to close the current file and open a new file in a differnt directory
(which is specified by a shell command). Since this proposal provides
a different mechanism by which the directory for the file is specified
I think it reasonable to request that Geng Xiaosong should poll the mail list
to see how many users are using the current mechanism and after
having an E-mail discussion with William Lupton (the author of KECKs
changes - [email protected]) arrive at a solution that hopefully is
acceptable to everyone. We could incorporate both mechanisms but perhaps
this would not result in a compact implementation which I think we all
prefer in the end.
Some specific comments follow:
> Problem background
> - Seperated log files to record the messages from different IOC's.
> But, some sites will continue to prefer to keep messages from several
> IOC's in one file.
This is possible (but possibly inconvenient) today. The (perhaps awkward)
restriction is one log server per file.
> - Run time reconfiguration of iocLogServer.
Today it is possible to dynamically change the log file directory (but not
the log file name) via SIGHUP.
> Proposal:
> - Use one configuration file to specify all parameters for the server.
> - One chapter should consist of information where messages from particular
> must be saved:
> <IOC name>| <full path> |<size limit>|<versioning>|<mail address>
> heraVME00 |/.../heraVME00_log.text|1000000 | Y |[email protected]
> heraVME01 |/.../heraVME00_log.text|1000000 | Y |[email protected]
> heraVME02 |/.../heraVME02_log.text|4000000 | Y |[email protected]
> heraVME03 |/.../heraVME03_log.text|239093 | N |
> * msg from heraVME00 and heraVME01 will be saved in ONE file
> - To add a new variable "EPICS_IOC_LOG_CONFIG_FILE" which should keep
> full path to the configuration file.
> - Send the signal SIGHUP (kill -1 <pid>) to iocLogServer to forse it to
> read config file again a make inner reconfigurations. (to be discussed)
> In start time:
> 1. iocLogServer <path to config file>
> 2. If ``config_file'' does not specify in command line then read
> system env. variable EPICS_IOC_LOG_CONFIG_FILE.
> 3. If env. does not exist, then use today approach.
> Problem background
> - Once the file is written fully, we need a possibility to inform
> the system manager about it and stop writing.
I assume that this would occur if "versioning" is "Y" otherwise if
"versioning" is "N" the current behavior of overwriting the oldest
log message would be preserved.
> Proposal:
> - IOC log sever will check itself whether a new month has started and
> crate new log file /xx/yy/mm/logfile.
How does this interact with KECK's changes which allow the new directory
to be determined via SIGHUP and the IOC log file command pipe?
> - Send a mail to the system manager to tell about this.
Should we restrict the mail message rate?
Jeff
______________________________________________________________________
Jeffrey O. Hill Internet [email protected]
LANL MS H820 Voice 505 665 1831
Los Alamos, NM 87545 USA FAX 505 665 5107
- proposal: IOC logger Geng XIAOSONG
Re: proposal: IOC logger watson
<1996>
2025
2026
<1996>
2025
2026
