1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: OPI version of errMessage()?
To: [email protected]
Date: Wed, 23 Oct 1996 15:45:38 -0500
I have completed my latest round of work on the APS logDaemon
(a simple distributed message logging system).
We have been using it successfully for logging from workstations
for about 9 months. Note that it is a single threaded UDP based
server, and that no message throttling is provided. It supports
a simple ascii file format as well as (optionally) SDDS.
The web page document is updated, and the source code is also
available for ftp from the web page. See:
  http://www.aps.anl.gov/asd/oag/oagSoftware.html
Note that the extracted tar file creates a directory structure
almost identical to that of epics/extensions. You should be
able to simply "cd oag/apps/src/logDaemon" and then "gnumake".
I do depend on the directory /usr/local/epics/R3.12.1.2, but
you can change that in oag/config. I think I only use the
linked list library in epics/base, so any version of epics
will suffice.
If you just type "gnumake", it will create a logDaemon
which writes simple text files. To use the SDDS file format,
you will need a recent copy of epics/extensions. Given that,
you can type "gnumake USE_SDDS=1". Note that introducing
a new file format for the output is fairly easy, so if
you have a favorite library for writing files...
This logger has proven more than adequate for many of our
needs, however I do recommend looking seriously at the
TJNAL (CEBAF) logger when it comes out in a few months.
The design goals of the CEBAF logger are considerably more
lofty than mine :)
 | Claude Saunders              | Operations Analysis Group         |
 | Argonne National Laboratory  | [email protected]                  |
Prev: RE: A/D card for VME Matthias Clausen DESY -MKS-2/KRYK-
Next: frc64/frc604RT performance Noboru Yamamoto
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: OPI version of errMessage()? Marty Kraimer
Next: CVS on win{95,NT} Jeff Hill
