1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: seqChanShow switches
To: [email protected]
Cc: [email protected]
Date: Wed, 6 Nov 96 14:47:51 MST
> From [email protected] Wed Nov  6 09:29:12 1996
> Return-Path: <[email protected]>
> Date: Wed, 6 Nov 1996 16:26:31 GMT
> Subject: seqChanShow switches
> To: tech-talk <[email protected]>
> Priority: Normal
> Mime-Version: 1.0
> Content-Type> : > TEXT/PLAIN> ; > CHARSET=US-ASCII>
> Content-Length: 203
> X-Lines: 11
> Greetings all,
> According to the SNL & Sequencer User Guide the 'seqChanShow' command has an
> option to display only the unconnected channels. Can anyone tell me what the
> switch is?
> Cheers
>  -- Sean
Hi Sean,
I looked in the code for seqChanShow and it appears
that
seqChanShow (<tid>, "-")
(where tid is the task id of the sequence)
will do it.
seqChanShow (<tid>,"+") will list only the connected ones.
Please try this.  I don't have access to a running sequence
right this minute.
Rozelle
|Rozelle Wright              Phone (505) 667-4804       |
|Los Alamos Natl Labs AOT-8  FAX (505) 665-5107         |
|PO Box 1663 MS-H820         Group Office (505) 667-6087|
|Los Alamos, NM 87545        email : [email protected]   |
Prev: Re: Problem with sync groups and C++ clients Jeff Hill
Next: How to connect to mbbo records? Len Lawrence
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: seqChanShow switches Sean Prior
Next: Problem with sync groups and C++ clients Guy Jennings
