1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Using g++ with 3.13 beta2
To: [email protected]
Date: Fri, 8 Nov 1996 09:32:07 -1000 (HST)
We don't use c++ much at all here so the latest releases are testing
us... We don't have the c++ compiler from Sun and so are forced to use
g++, and we are finding it has a problem with variable argument lists.
Does anyone know the way around this? It is a known problem we have with
g++, but it hasn't worried us before and we have never found the solution.
The problem first occurs when compiling gdd.cc:
/opt/gnu/bin/g++ -ansi -pedantic -Wall -O   -DSOLARIS   -I. -I.. -I/ukirt_sw/epics/R3.13.0.beta2/include  -DUNIX   -c ../gdd.cc
../gdd.cc: In method `long int gdd::copyStuff(class gdd *, int)':
../gdd.cc:427: warning: suggest parentheses around assignment used as truth value
../gdd.cc: In method `long int gdd::copyData(const class gdd *)':
../gdd.cc:1389: warning: comparison between signed and unsigned
../gdd.cc: In method `gddAtomic::gddAtomic(int, aitEnum, int ...)':
../gdd.cc:1418: `__builtin_va_alist' undeclared (first use this function)
../gdd.cc:1418: (Each undeclared identifier is reported only once
../gdd.cc:1418: for each function it appears in.)
../gdd.cc:1421: warning: implicit declaration of function `int __builtin_va_arg_incr(...)'
../gdd.cc:1414: warning: `void * ap' might be used uninitialized in this function
gmake[1]: *** [gdd.o] Error 1
gmake[1]: Leaving directory `/ukirt_sw/epics/src/R3.13.0.beta2/base/src/gdd/O.solaris'
gmake: *** [install.solaris] Error 2
The relevant lines are:
1411: gddAtomic::gddAtomic(int app, aitEnum prim, int dimen, ...):
1412:                 gdd(app,prim,dimen)
1413: {
1414:         va_list ap;
1415:         int i;
1416:         aitIndex val;
1417:
1418:         va_start(ap,dimen);
1419:         for(i=0;i<dimen;i++)
1420:         {
1421:                 val=va_arg(ap,aitUint32);
1422:                 bounds[i].set(0,val);
1423:         }
1424:         va_end(ap);
1425: }
There may, of course, be other problems but my build hasn't got that
far...
I did ask once which c++ compilers were to be supported but got no
reply - I also know Jeff said at one point that he managed to compile
base with gcc and g++, but I don't know whether it still does. How
about the situation that I have - is using Solaris c (because nominally
we only support the vendor supplied C compilers) with GNU g++
supported, or is there a library problem sometimes? How does all this
effect our support for other hosts (Linux, HP etc?).
I would dearly like someone to clarify all this because now it is
impossible to compile base without a c++ compiler of some sort or
other.
Cheers,
Nick Rees
Joint Astronomy Centre                    Ph:       +1 (808) 961-3756
660 N. Aohoku Place                       Fax:      +1 (808) 961-6516
Hilo, HI.  96720                          Internet: [email protected]
Re: Using g++ with 3.13 beta2 Jeff Hill
Re: Using g++ with 3.13 beta2 Kazuro FURUKAWA
Prev: 3.13 beta4 Marty Kraimer
Next: Re: RAWL/RAWH Marty Kraimer
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Using g++ with 3.13 beta2 Jeff Hill
