I modified z8530Serial.c to set odd parity and do some break manipulations,
using ioctl calls. It may not do exactly what you need but it might be
helpful to look at.
Carl
// Carl Lionberger [email protected]
// Computer System Engineer Voice (510) 486-7503
// Berkeley National Laboratory Fax (510) 486-5101
> > Is there a way to set parity (none, even, odd) on a 162
> > serial port running vxworks 5.2? I see how you can set
> > just about everything else using "ioctl" but not parity.
> > I have a power supply that requires "even parity".
> > I know that there is an option (OPT_7_BIT) to strip the parity bit
> > on incoming data but no way of transmitting with even parity.
> The source to the tty driver for the mv162 seems to only cover the
> baud rate in its hardware-specific portion. If you are REALLY stuck, you
> can cheat by accessing the 8530 serial controller directly or adding the
> proper IOCTL code to z8530Serial.c in you vxWorks distribution and
> recompiling it. Either way, you will want to use the 8530 driver as
> an example of how to use the chip.
> --John Winans
Re: Help w/PulseTrain and PulseCounter using Mizar 8310 board Marty Kraimer
New extensions available Bakul Banerjee
<1996>
2025
2026
Re: RS232 Configuration Question on MVME162 Graham Waters
seqChanShow switches Sean Prior
<1996>
2025
2026
