1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: RTYP ?
To: Pete Jemian <[email protected]>
Cc: [email protected]
Date: Thu, 14 Nov 1996 10:24:25 -0700
Pete Jemian wrote:
> Is there a field of a process variable that identifies what
> type of record (maybe RTYP) the variable is?
sorry, no.
> How can a Channel Access client find out what type
> of record (ai, ao, steppermotor, etc.) a particular
> process variable is?
When we designed EPICS we intentionally isolated the
CA clients from any changes which might occur at the record
level. We wanted to avoid a situation where source code
changes at the record level resulted in parallel source
code changes in the general purpose clients such as dm,
medm, alh, etc. This approach has resulted in lower
maintenance costs for the client side tools.
While we feel that in general it is undesirable for high
level general purpose tools to know what record they are
attached to, we also see that in many application specific
situations it would be quite useful to have access to this
information. Perhaps we should add a new "record
type name" data type to the database access level  (which
I assume could only be fetched as a string). Client
requests fetching this type against an old CA server
that does not support it would be refused.
Is there general interest in this change?
Jeff
______________________________________________________________________
Jeffrey O. Hill                 Internet        [email protected]
LANL MS H820                    Voice           505 665 1831
Los Alamos, NM 87545 USA        FAX             505 665 5107
Re: RTYP ? Bill Lavender
Re: RTYP ? Gabor Csuka
RTYP ? Pete Jemian
Prev: RTYP ? Pete Jemian
Next: Transmitter controls suggestions? SIBLEY
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: RTYP ? Bill Lavender
