1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: 3.12.2 patch
To: [email protected]
Date: Thu, 14 Nov 1996 15:14:55 -0700
hello all,
As requested a patch for 3.12.2 has been prepared that fixes the
following two problems:
Bug number (1)
Symptom: Error messages about invalid sync group id when
running CA client side test "acctst.c". This problem has
been observed with gcc 2.7.2 and with a recent version
of the VMS C compiler when optimization is enabled. This
problem has not been observed in code compiled by the gnu
C compiler supplied with vxWorks 5.2 or with sun pro {4.1,
4.0.1}.
Fix: Removed use of "const" in the CA client API typedef
"CA_SYNC_GID" in cadef.h.
Bug number (2)
Symptom: CA client lib incorrectly prints disconnect message
when a connection to a particular IOC is deleted because
the last channel using that connection was deleted (by
the client side tool).
Fix: Dont print a disconnect message in this particular situation.
The above changes have been committed to the 3.12.2 CVS branch
at APs.
Jeff
______________________________________________________________________
Jeffrey O. Hill                 Internet        [email protected]
LANL MS H820                    Voice           505 665 1831
Los Alamos, NM 87545 USA        FAX             505 665 5107
Prev: Re: RTYP ? Tim Mooney
Next: Re: RTYP ? Gabor Csuka
Index: 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Training laurence lurio
Next: SLC 500 support under R3.13Beta4 S. Joshua Stein
