1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RTYP ?
To: [email protected], [email protected]
Date: Fri, 15 Nov 1996 10:12:13 -0700
Hello all,
After some off line discussion about this request for a modification
to the ca client API allowing the record type and name to be queried.
we have come up with the following potential solution.
A new data type could be added to the dbr_XXX types in db_access.h
and a new PV attribute application type could be added to the
gdd self describing data class as follows:
gdd			ca client		EPICS DB subsystem
gddAppTypeClassName	DBR_CLASS_NAME		the record type
gddAppTypeInstanceName	DBR_INSTANCE_NAME	the record name
This would allow an application to directly query an EPICS
database PV's record name and type. Other subsystems underneath
of the CA server would of course implement different mappings for
these attributes.
The PV model present in the ca client API and the database
access API has had some success fostering a tool
based approach. Currently, we have two types of PVs:
o Analog with limits, units, etc
o Enumerated with strings associated with each state
I suspect that in many cases the users need to know the record name
only because they need to modify PV attributes such as the units
and the limits by poking directly in record specifc fields? If so,
perhaps the immediate need is to provide write access to the
compound DBR_XXXX types from the ca client API. This will perhaps
avoid changes in application level code when the record type
changes for a particular record instance in the database.
Any comments?
Jeff
______________________________________________________________________
Jeffrey O. Hill                 Internet        [email protected]
LANL MS H820                    Voice           505 665 1831
Los Alamos, NM 87545 USA        FAX             505 665 5107
Prev: Re: RTYP ? Pete Jemian
Next: Re: frc64/frc604RT performance KAJI Masahiro
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Transmitter controls suggestions? SIBLEY
