I have two problems with the steppermotor record / OMS driver.
First: It provides no direct control over the AUX line. It always
enables the line before initiating a move, and disables it after the
move is complete. This is desirable behavior under normal operating
conditions; however, it causes problems for me during my initial
calibration procedure. I need to be able to leave the AUX line enabled
for an extended sequence of calibration operations, and return it to
its normal operating mode after calibration is complete.
Second: As far as I can tell, it provides no way to set the velocity
profile (other than the acceleration). Specifically, I would like to
be able to set the OMS base velocity.
I believe that I will need to modify the record and driver to provide
this support. Is this correct, or am I overlooking something? Has
someone else already done one or both of these? If I do make the
changes, who do I contact to get the changes merged with the standard
release?
As an alternative, I have been given a 'motor' record, written by Jim
Kowalkowski and Joe Sullivan. It provides the second function that I
need. I would still need to add the first function. Has anyone had
experience with this record? Are there any special problems with it?
Is there a reason why this record is not part of the standard EPICS
release (I'm using release 3.12.2, with Gemini modifications)?
Any information would be appreciated.
Hubert Yamada, University of Hawaii, Institute for Astronomy
phone: (808) 956-6648
e-mail: [email protected]
WWW: http://ccd.ifa.hawaii.edu/~yamada/
Re: Hardware Configuration Marty Kraimer
[no subject] Tien Doan
<1996>
2025
2026
MEDM under fvwm Peregrine McGehee
<1996>
2025
2026
