Subject: |
RE: IP support |
[email protected] |
Date: |
Fri, 13 Dec 1996 18:19:19 +0100 (MET) |
Jim writes:
>I've been reading the IP support mail messages over the last couple of
>hours on tech-talk and I guess I have a question about all of it and a
>few comments. I've read through all of your stuff, so I might as well
>throw my stuff out here too.
>I see three basic IP developments in process, maybe four:
> 1) telescope community (Andrew/Peregrine)
> 2) IRM developments and other (Matthias/DESY/Fermilab)
> 3) HiDEOS
In fact there are several ways to communicate with serial IP's:
-telescope community (Andrew/Peregrine) partly using HIDEOS
-DESY using CDI (which runs under VxWorks and support single and multiple CPU's)
-ANL HIDEOS
-BESSY - there way to do it
There have been enough arguments about HIDEOS/CDI and others.
It's not religious. There are finacial arguments: (HIDEOS does not need VxWorks licences)
Technical arguments etc. and I do not believe that any programmer who did this job will
want merge his code with another one.
The actual version of CDI is now optimized for asynch. I/O and can handle even bulk data
with might be connected to sevel(hundred) of EPICS records in a most efficient way. This
development took Gabor a lot of time to optimize the code. I am sure we will not want to
move to any other code.
You as the EPICS community have tha chance to pick what you like.
Looking at the history of CDI - this in fact was already running 1 year before HIDEOS was
developed because we already used it under VAX-eln (who ever knows this 'strange'
operating system). But this only for clarification.
The arguments for the register-based drivers for IP modules are surely true and in fact
the drivers written for the IP-modules in the Fermilab-IRM's are NOT using CDI but are
written in the same way as any other VME-IO drivers.
Are there so many common aspects on the IP drivers that you might want to standardize on?
What's the difference to the VME drivers?
Well - it would be worth thinking of something like auto-configuration of IP modules...
Is this the idea?
We need in general some standards:
for serial IO we already have at least 4
for direct IO ?
- auto configuration?
- others?
Matthias
- Re: IP support Ralph Lange
Re: IP support watson
IP conversation, my 2 cents RON
<1996>
2025
2026
<1996>
2025
2026
